disable switch locally-administered-address
disable switchlocally-administered-address
Description
Disables the switch from generating locally administered per-port MAC addresses.
Syntax Description
Default
This feature is disabled by default.
Usage Guidelines
ExtremeXOS switches do not use a unique per-port MAC address when transmitting bridge protocol data units (BPDUs). As a result, switch management can become inaccessible when switch MAC addresses are learned on the wrong L2 path (corresponding to a blocking port). This command allows you to disable the switch from generating locally administered MAC addresses.
The following example disables the switch from generating locally administered MAC addresses:
This command was first available in ExtremeXOS 22.3.
Platform Availability
